Whenever I park up after a decent drive, I seem to get a very small puddle of fluid appear under my gearbox end. Maneuvering the car in and out of the drive and playing with the suspension
doesn't produce this elusive fluid - even after being parked up for 24 hours, it only seems to appear after a long ride out. Judging from whereabouts the leak originates (see pictures) - I reckon it's gearbox oil - caught some on the end of my finger and it took alot of soap to get the greasiness off. How can I check the fluid level? It's a 1991 XU5S and the Haynes helpfully just says "there's a filler/level plug on the gearbox end cover"...
The leak is only directly under the gearbox end cover (see where it looks "wettest"
The diff housing also looks "wet" but there was no leaking underneath here.
As did the accumulator sphere area, but again no evidence of leaking underneath, and the reservoir was at "max" (in high with engine on) so I ruled out an LHM leak
And finally a slightly better pic of the transmission end - maybe when the oil has warmed up it's thin enough to escape through a loose screw? Really have no idea...
Cheers, Will
