Hurricane Remote Door Lock
cms
Post by cms »
Hi, this is my first post so I hope it's in the right place.
After many years of being lost, I have found the remote door lock sender under one of the seats minus the battery.
Has anybody an idea of which battery they took as I cannot find a mention of it anywhere in the manual.
Thanks.
You need 3, of the AG13 size, also known as LR44 amongst many other names. The SG13 or SR44 equivalents are the same size but silver oxide chemistry rather than alkaline, so will last longer.
Oh, and welcome along! :)
i think the LR44 would last longer as its lithium,
cms
Post by cms »
Brilliant, very quick reply, thanks a lot.
Originally they had this weird little single mini-AA type affair. You can still buy them, but I\'ve no idea what they are!
Post by RxBX »
mat_fenwick wrote:You need 3, of the AG13 size, also known as LR44 amongst many other names. The SG13 or SR44 equivalents are the same size but silver oxide chemistry rather than alkaline, so will last longer.
Kitch wrote:Originally they had this weird little single mini-AA type affair. You can still buy them, but I've no idea what they are!
Hi Matt, Kitch /\ is correct as the actual designed voltage for the plip to work correctly is 6 volts so by only placing 3xLR44 cells end to end presumably sellotaped together (as I've often seen) will only give out 4.5 volts and therefore will be like fitting a used (on its last legs) battery and will probably compromise the distance of the plip to receiver operation too !
The correct battery type for the plip/transmitter are known as an '11A' like THIS-ONE ( Pack of FIVE or 99p on E-BAY ) :D
I also looked for, in my book-marks for 'Rob-smiths' guide on the spec.repair/coding of the plip but unfortunately it no-longer works :(
Did any one possibly down load/save that PDF file ? as there was a-lot of useful info on his site, as it clearly stated/showed that the plip transmitter operated on 6 volts !
RxBX wrote: I also looked for, in my book-marks for 'Rob-smiths' guide on the spec.repair/coding of the plip but unfortunately it no-longer works :(
That was an excellent resource and a great loss to the community that it's no longer on-line.
Does anyone know Rob Smith or his contact details? If it's just a hosting issue maybe one of the BX or XM forums will have spare capacity to accomodate it. It was that good that it should not be lost.
themildbunch
Post by themildbunch »
All is not lost online!
I found his site this week in the wayback machine which captures sites as an ongoing process... his site is backed up here with all the useful pdfs intact..
http://www.archive.org/
Really useful site.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
citronut wrote:i think the LR44 would last longer as its lithium
The LR is also alkaline, maybe you're thinking of the CR series of batteries which are lithium?
RxBX wrote:The correct battery type for the plip/transmitter are known as an '11A'
That is interesting, as I've simply replaced like for like when changing keyfob batteries, and of the two I've seen both have had the wrong ones in! No sellotape though, otherwise that would have set alarm bells ringing that it wasn't the correct type. Range has never been brilliant...
Post by RxBX »
themildbunch wrote:All is not lost online!
Really useful site.
But all is not there on the PLIPS unfortunately as some PDFs are missing :(
Likewise with a few of the other PDFs in the directory LISTINGS (if you care to have a quick breeze thro' them) but much better than not being able to see nothing at all !
..that_ Same as Matt on this one, mine too was fitted with the 3 LR44 not selotaped together and i rplaced like for like to try and make it work better as it was poo and had no joy. I've now replaced it with a ZX one that isn't much better. I will have to try the original with the correct battery and see if that is an improvement.
Well done 'Richard font of all knowledge'
Oh and Welcome along CMS! ^^bx>
RxBX wrote:But all is not there on the PLIPS unfortunately as some PDFs are missing :(
I can see the PDF for the TEA5500 chip, but not the jpegs. I think I saved them a few years back so will have a look. I notice that from the spec sheet the voltage for the circuit is given as 3V min, 4.5V typical and 6.5V max, suggesting that it should work fine on 4.5V. I reckon the main issue is the fact that the 3 batteries aren't making ideal contact with each other - something I'd just put down to the fact my casing is held together with glue and a zip tie!
Have ordered a battery anyway :)
They make work on 4.5v but with 3 batts instead of one you have 4 contacts instead of 2 which could make it less reliable maybe?
/ \ Yes, that's exactly what I meant. Will report back when my new battery arrives!
