Steering knock
Steering knock
The new BX has some serious clonks from the front end. Can't feel any play in the ARB drop links or the balljoints (though one was an advisory last year) but there's a very distinct clonk on the LH track rod when I pull along its length. I'm guessing this is the inner track rod. What sort of a job is that to change? The part itself doesn't seem too pricey. Mike - knowing you did both on the Mk1, I'd appreciate your thoughts! Did you change them while the rack was out?
Re: Steering knock
Sorry - the recon rack came with inner joints!
I have done the same job on the GS, and if it's anything to go by it should be an easy job
B-Hive
Re: Steering knock
If it is the steering axials, I have to say that it would be a job better done with the whole steering rack out.
It was one of those jobs that I kept putting off on the first Mk1 TRS..Access not great and you need sometimes quite a bit of "persuasion" to nip them loose.
Steering rack is not an awful job, but not super easy either.. But once out it does also make it a snap to put on new gaitors and a fresh hardy disc.
Also worth checking the sub frame bolts are tight, its also very hard to test for balljoint/bush and drop link wear as the suspension system is rarely neutral (its either in tension or compression)
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
