Oil leak TZS Auto
Oil leak TZS Auto
Not sure on the exact cause of this the location seems to show pooling of oil just below some green covered sensor type thing I am not sure of the purpose without checking. which is above the oil filter. Checked the breather pieps in that area and they are dry so likely candidates please. The one I can think of the most is Oil Filter blowing passed the gasket at pressure?
1990 BX19 TZS Auto 06/11/1989
Geoffrey Gould
Re: Oil leak TZS Auto
Hi oil pressure switch may be culprit. A leak from these is not unknown.
G.
G.
1991 BX 1-7 td Auto.
NEVER WRONG.
NEVER WRONG.
That would be what that sensor is called, it got me confused on a quick look being a differant colour than on the other two petrol BXs.
You say not uncommon? Its the first I have come across in 20 plus years so once gain the BX are throwing out another learning curveball.
I changed the one on Timex because it wasn't working, but it looked much the same as those fitted to 2CV's, which are known for leaking.
not really hi oil pressure but just the oil pressure switch,
and yes they can leak,
i have seen this on 2CV's and G's
