Front screen washer not working
greendale65
Post by greendale65 »
Hope you are all ok
Can you tell me where the front screen washer pump is
is it under the water top up drivers side so i can check
ok it maybe the fuse or the stalk.
Thanks all
8) :)
panky
'88 BX GTi (a long time ago)
x 175
Re: Front screen washer not working
Post by panky »
If it's the same as mine then the pump is on the side of the screen wash bottle. Is the pump running? It could be a blocked spray bar on the wiper.
greendale65
Hi pump not working i've replaced on other valvers but
i;'m pretty sure i removed the bottle which is a pain
dont want to do that if its not there.
panky
x 175
Post by panky »
Have a peep at the bottle and see if you can trace the wires
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 82
Post by Dave_16v »
It just pushes in at the side of the bottle, easy to see. A good chance if you remove the plug, give it a clean and the connections on the pump, it might work. They get a bit corroded. Hope that cures it. 🙏
greendale65
Hi ,
Thanks all you could be right on that as said have changed them
i did look but not that hard not in a rush a moment mot September
i'm 85 old so things happen as you go now waiting for a full knee
replacement so don't use the car these days when sorted the car
will reply .
Thanks all
8) 8)
Dave_16v
BX Gti past
BX Gti Auto past
x 82
Post by Dave_16v »
OK Alan, keep well 👍
Dave_16v
BX Gti past
BX Gti Auto past
x 82
Post by Dave_16v »
In case you check back, here's mine. Pull the plug off and reattach it, if that does not solve it initially, take it off and clean all the connections. After that, it's a process of elimination.
x 117
Hope you get the new knee soon. Its a long wait where I live which tempts many to go privately.
Despite running many half marathons and skiing a lot for 40 years mine are, surprisingly, still OK.
