A huge 'If'...
- x 27
A huge 'If'...
'If' I was mechanically skilled and had the time, space, money and equipment I would have it. C'mon save it, someone!
Quick...
http://cgi.ebay.co.uk/1991-Citroen-BX17 ... dZViewItem
Quick...
- Keeper of the site Goat
It`s a fair old trek for most of us too. What that needs is a 1.9TD lump in it and to be resprayed in white, then VOILA! the perfect BX!
It looks reasonable value for money if someone has time and skills to replace the engine, be nice to see on of our mob buying it and saving it. Over to you, Ken?
Vauxhall apologist.
tim leech
RichardW
- BX Digit man!
Well, I could easily tow it back from scotland, and a BX estate is the only one I really fit into properly (for headroom)
to follow on from Richard above:
Skills? Yes.
Experience? Done so many I've lost count.
Tools? Somewhere in the garage.
Time? Not a single moment available.
A huge stack of other projects that will keep me busy for years to come? You betcha.
ar$e.
Skills? Yes.
ar$e.
Stewart (oily!)
Skills, yescavmad wrote:It`s a fair old trek for most of us too. What that needs is a 1.9TD lump in it and to be resprayed in white, then VOILA! the perfect BX!
tools, yes
time, yes
want it, yes
space, maybe not
So how the hell do I get it home.
- BX Digit man!
- Our Trim Guru
This car has the less common grey "Z" interior as opposed to the more usual grey and black. Very unusual in a red one - more often seen on the white cars.Save this style icon, someone, please, so long as the rear arch rust is not like some of the recent examples on ebay.
Edinburgh is where I came in to the world, but since leaving in 19humpthy-humph at the tender age of eight years I've only been back once, on a rather mad drive-up-today-and-back-tomorrow trip.
Martyn
- x 27
- BX Digit man!
Yes.mott999 wrote:Would it not need a head skim?
Head off, Strip out camshaft and followers. Have head skimmed.
Measure head bolts for new if needed (probably not... they're usually in tolerance)
buy multi-layer steel-laminate gasket, head set, cambelt and water pump.
Grind in valves. Set clearances.
Put everything back together.
Drive.
