I have a question (or two). When did plastic coated pipes come in? (my understanding is 1990 with the - confusingly - 1991 model range, which also included smoked rear lights on all hatchbacks and the black chin spoiler on the TZD Turbo and TZi/GTi's).
Is it possible to change the older pipes on, say, a 1989 car with the plastic coated ones or is this a waste of time (and too expensive)?
What ORGA number range differentiates the Phase 1 from Phase 2 Mk II BX?
Pipes
It was simply a change of material - new coated ones simply fit exactly as the uncoated ones did - and if you buy genuine Citroen the come pre-bent and go straight in (unless they are the rear ones which have to be threaded round the subframe.)
The old ones are fine till they rust! If they're good a coat of waxoil will prevent corrosion if you can get it on them!
Most cars will have had the front-rear pipes changed by now. My 89 car needed them in 2000 at about 170,000 miles.
Stewart (oily!)
- x 94
