1, Fuel Sender recently replaced this with a second hand one and now I have a twitchy needle. There is a small dent in the cylinder but dont think that affects the float travel.
Most disconcerting when you do a quick flick of the instrument panel just before doing a overtaking manauver on a narrow road
2, Drivers Door warning light, keeps sticking on best advice to cure that please? Last time I tried one of these I ended up losing it in the bulkhead
3, Would you believe the Heater control has jammed thats going to be fun trying to flush or worse remove and flush. I know from experiance.
Other than that the only other thing I noticed is she is a pain in the arse to start in the cold compared to my Korean Vauxhall Astra Auto.
