Useless PSA lead battery clamps.
... and how to bin them forever.
The standard lead battery clamps on almost all PSA vehicles are a waste of space. They cause problems with poor charging and poor starting, will stretch over time to come loose, and have been known to come off completely.
I hate them. If you do too, do this:
The negative clamp on my BX was suffering from dissimilar metal corrosion from the steel bolt. It would come off the battery simply by sneezing nearby. It had to go.
So you get one of these. It's a standard rubbish cheapo battery clamp from any motor factors (or dare I say it, even halfrauds) Note that the screws that normally clamp the cables have been removed (as this is the reason why they're normally rubbish.)
Hack the old clamp off the cable. Not difficult since it's lead. Cut back about an inch of the insulation on the cable.
My replacement clamp was a very cheap small one, and the hole for the cable wasn't big enough. This is it being drilled out.
... and having a countersink put on the cable entry to make it easy to get the cable in.
Cable inserted into clamp.
Now, I don't have photos of the next bit, so bear with me. You'll need a blowlamp, some plumbers flux and plumbers solder. Dip the ends of the cable in the plumbers flux and then assemble as the photo above. Now heat the clamp up until you can feed solder in through the holes vacated by the cable screws. Feed in solder until it drips out from somewhere, then allow to cool.
What you will then have is a nice soldered joint into a brass battery clamp. Way better than the PSA type.
And that's the result. You can now do this clamp up tight without worrying about stretching it, or having the bolt/nut pull all the way through the clamp.
Note that I've used an M8 nut and bolt in this clamp. There's a good reason for that: the standard square-head bolt used on these clamps is a 1/4 Whitworth, which although I do have the correct spanner for, I don't carry one in my "emergency" toolkit. I do, however, carry a 13mm.
Having done this the engine cranked noticeably faster. I can only imagine how hot the terminal was getting during cold-starts.
ellevie
Forum Treasurer
Post by ellevie »
Nice David, that's worth remembering.
I'm always apprehensive about over-tightening the clamp nuts. I remember years ago I once thought I had completely ruined one of the clamps by over-tightening the nut, but then I realised that the battery terminal post is slightly tapered and that I wasn't pushing the clamp down enough.Since then, I always push the clamps down fully and tighten the nuts just to the point where I cant rotate the clamp about the terminal post. Touch wood, I've been lucky so far.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
m_2975
My Cars: 1989 BX 19TRI Estate
1993 BX GTI
1997 Xantia CT Turbo
Post by m_2975 »
I wouldn't call the PSA battery connections the world's best invention by a long shot, but they are certainly nicer looking IMO, especially when they are new.
They can be a real piece of $h!t when the square headed bolt starts turning instead of staying like it should and the nut is would all the way in and it's still loose!
We normally remove the bolt and cut a small piece out of the middle to make it tighten and it always works.
Nevertheless, your idea looks really good. Brass connection, soldered cable, it's something very useful.
Thanks for the post
Michael
My Cars:
'93 BX 19GTi Sedan 5M
'89 BX 19TRI Estate 5M
'89 AX GT(With EFI) 2door 5M
In the Family:
'74 SM IE (Fully Restored) 5M
'90 BX 19TRI122 Sedan 4A
'06 C5 2.2HDi Estate 6A
Nice work mate!
Being bling I of course have GOLD terminals on mine.....
Did someone mention bling?
Sorry....I know my battery wasn't bling enough, so it got replaced! :lol:
Whats that fancy red lead to the right of the battery (next to sphere)?
Powers the amp in the boot
aha, must be bit of a beast then...
Not really, that wires pretty thin by decent standards. :lol:
m_2975
1993 BX GTI
Post by m_2975 »
I've got one of those funny red wires too.
Mine's a bit thicker and powers a 4x150W power amp under the passenger seat. Nothing special really and I didn't really want it but I was told that I must have it (the wire that is!) :roll:
You can see the cable entering the cabin just behind the left of the battery and you can see the cable connected to the battery. The large fise is hidden behind the battery itself.
My Cars:
In the Family:
Mike E (uk)
Post by Mike E (uk) »
I replaced my cable terminals too, but I used the quick release type with levers on so they can be removed instantly without any tools.
CPC.co.uk sell them.
I chose them after I had a starter solonoid fail short circuit.
Kitch wrote:Did someone mention bling?
Mine are a bit more bling, but similar, I'll take some piccies tomorrow, er, today.
M_29758767437543566574365874365 wrote:I've got one of those funny red wires too.
You also have two very random wires escaping from your engine bay!
Maybe powering the lights in the garage........
m_2975
1993 BX GTI
Post by m_2975 »
docchevron1472 wrote: You also have two very random wires escaping from your engine bay!
HAHAHA....No charging the not very "bling" battery that should be at the tip!
:lol: :lol: :lol: :lol:
My Cars:
In the Family:
