1991 19TGD Silver Estate
Needs a clutch, could be a bargain if you can do it yourself....
http://cgi.ebay.co.uk/1991-CITROEN-BX19 ... dZViewItem
Hhmm, I know this car, it's actually quite tidy, and I know Manni very well indeed.
Dont like estates myself, but I might just have a pop at that.
Wham a clutch in it, and fire it on, maybe it'll even turn a profit!
Actually, I've just had another thought......
hhmm......
Crows, flies, east.
hhmm......
Crows, flies, east.
cpt_spalding
stuart_hedges
cpt_spalding
cpt_spalding
Well yeah, but ANY manual car will need a clutch eventually.
Pi$$ poor idea if you ask me.
Vauxhall had it right with the Cav's. 15 minutes to change a clutch, at the side of the road. In the dark.
Now that box was designed by an engineer.
- BX Digit man!
Ironically, it also had an extremely good clutch in it, which if you drove appropriately never needed changing.docchevron1472 wrote:Vauxhall had it right with the Cav's. 15 minutes to change a clutch, at the side of the road. In the dark.
My father bought a Cav mk2 branders spankers in 1988. He drove it lots. Mum drove it a bit, and then I drove it lots too. Best part of 200k on it when the tinworm finally killed it, and it was still on the factory clutch. Mind you, it was also still on the factory head gasket, gear oil, CV joints, etc. The only thing that car ever needed other than service items was a starter motor. (and even that turned out to be worn out brushes)
