Xantia MK II Radio
Xantia MK II Radio
Well, my Xantia nearly did fail to start this morning - it was -5°C and it was deffo reluctant to turn over, so I am thinking might be time for new battery before it really is "My Xantia won't start in the morning" time Trouble is, no radio code. How does the radio come out? Was going to see if the code was written on it, or try and get the serial number decoded before I have to grease the dealer's palm to get the number (or maybe you can get it via citroen-service...???).
I NEED a BX TD.
- Sir Jim of the Databases
Hi Richard,
very easily
gently prise off the trim around the radio and heater controls after removing the ashtray.
then, you'll find just two torx screws holding the radio in.
Your local Dealer will give you the code on production of VIN, proof of ownership and etc.
They'll charge from about zero to a tenner for this, depending on how they feel...
very easily
Jim
The only problem with the MK II radio, at least the 6 CD changer version, is the lack of Long Wave; not for the loss of Radio 4 but for the loss of an ability to "listen" to ones Hydractive Electrovalves...
Jim
Eh? Get on the MW band then tune straight onto LW, well it works on both of mine Jimcitrojim wrote:The only problem with the MK II radio, at least the 6 CD changer version, is the lack of Long Wave; not for the loss of Radio 4 but for the loss of an ability to "listen" to ones Hydractive Electrovalves...
Richard, don't forget to remove the two Torx 20 screws down by the ashtray before levering out the trim.
So it does I just had to venture out into the cold and try it.Dickieg wrote:Eh? Get on the MW band then tune straight onto LW, well it works on both of mine Jimcitrojim wrote:The only problem with the MK II radio, at least the 6 CD changer version, is the lack of Long Wave; not for the loss of Radio 4 but for the loss of an ability to "listen" to ones Hydractive Electrovalves...
Thanks Richard!
Jim
"Minus 5? where are you in the country?"
Lanark, Scotland. We're 200m above sea level so it can be quite chilly!
Thanks for the outline Jim, which is exactly as per my MK1's, but i don't think is going to work on my MK11. This car has a fold down flap over the radio which looks separate from the surround round the heater controls, and there are 4 holes in the front of the radio which look like they need removal tools to pull the radio out. More investigation required when I get to look at it in the light!
The radio is not bad - a bit poor at picking up weak stations though. Replacing it with a CD player had crossed my mind - I wonder if there are any that will work with the steering wheel controls.
I NEED a BX TD.
If it’s anything like mine, there are 4 torx screws holding the radio in, and the flap comes out with the radio.
The radio has to be disconnected from the car battery for several minutes before it loses memory.
It must have its own back-up battery or capacitor, but they do rot in time.
2002 C5 2.0i AL4 207,000 km 76372389
Ok, definitive: on this one the radio comes out first. You need a pair of the extractor tools (for which Halfords relieved me of > 4 quid FFS!), remove the plastic trim on the radio and then it just pulls out. The flap appears to follow after removal of 4 Torx screws.
No number written on the radio so off to the dealer
It appears to be a standard DIN radio though, so easy to fit another one if required
I NEED a BX TD.
