Hi All,
I have got a 2001 X reg 306 1.4 that has don 97k, I have started to notice a smell inside the car which is worse when the blower is not running, the smell to me is like a curry kind of smell.
Could this be as I suspect, the matrix starting to fail?
I have not checked the water level yet to see if it has gone down as the engine is still hot, I will check it in the morning.
Any help/coments appreciated.
306 smell, could it be the matrix?
- Sir Jim of the Databases
Yes, sadly, that is the first sign
However, having said that, they can go on a long time smelling a little and not leaking any significant amount of coolant.
All my Xantias smell a bit but only briefly. My Activa was worse at the start of winter. It seems where the flaps were closed against the matrix all summer, a bit of coolant built up and smelt for a bit. Touch wood, it has all gone off now.
I understand doing a 306 matrix is nearly as much of a task as a Xantia. The dash has to come right out
Jim
Glycol anti-freeze smells sweet - not like curry.
There were a number of posts on curry smells some time ago and apparently it can be a bacterial contamination of the matrix - which can be shifted with a specialist product - Halfords?
More common with air conditioning.
Other signs of leaky matrix is misting of the screen on startup (heater on etc - damp air condenses on screen)
If it is leaking try some K-Seal. I added some to my Xantia which showed signs of a leaking matrix so i waited until after the water pump/cambelt was done and added a bottle, it doesnt mist the screen up anymore, or smell. It's worth it for a tenner to save the hassle.
Gareth
Gareth
Xantia ActivaLX - Fuelled by SVO
Hi all,
Thanks for the replys.
It's been a couple of years since I used the air con cleaning stuff from halfords so it probably is worth me buying that and seeing if it helps.
I will continue to keep an eye on the coolant level as it does not appear to be using water, if it does though I think I'll go down the route suggested by Xantiaman and try some K-Seal.
Thanks again!
Thanks again!
