Had an MOT this morning, all ok and went straight through but had an advisory on the front lower arm bushes at the back. Are they easy to replace? Should i just get another brand new arm complete with bushes to save hassle? And also, if they are failing, would they cause a knock noise? I replaced my ARB links recently and balljoints are fine, but i still get a knock!
Gareth
Xantia lower arm suspension bushes (front)
Xantia ActivaLX - Fuelled by SVO
The big problem with fitting new bushes to the arms is that they must be fitted at exactly the correct angle on the arm otherwise they will split due to being under constant strain. As the bushes are an interferance fit getting it right isn't easy, so if you can find arms at a reasonable price that's a much easier solution.
99 Xantia HDi Exclusive Est
98 Xantia V6 Exclusive
97 Xantia VSX TD
72 DS 21 EFi Pallas
97 Xantia VSX TD
72 DS 21 EFi Pallas
- Sir Jim of the Databases
As Richard says, you have to take extreme care. There are alignment marks on both the wishbone and the OE bushes but often pattern bushes don't have them. In that case, you need to carefully note how the old one was and get the new one back on in precisely the same place. Easier said than done although if you freeze the wishbone and heat (gently) the new bush, they're not hard to drift home.
Also, the old bush is a bit tricky to get off. Usually it is necessary to resort to the hacksaw and in doing so it is incredibly easy to just "nip" the wishbone spigot with the blade. This is dangerous as it could cause a stress riser in a very heavily loaded area with serious consequences if the spigot broke as a result.
Do replace them by all means but please be careful.
Jim
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 91
