I am after a "How To" on changing the 4 figure code on my xantia key pad, would ask on french car forum but still won't let me on????
Any help greatly appreciated,
Cheers steve
Sorry Xantia Question Re security code change???
talbotsteve
AndersDK
CitroXim
- Sir Jim of the Databases
Hi Steve,
To change the code:
Ignition on
Enter current code, get the green light.
Press the "C" button, hear a bleep
Enter your new code
Press the "C" button, hear a bleep.
The green light will now flash four times accompanied by four bleeps.
Switch off ignition.
To program "Service" mode, a code for a garage to use but keeping your own code secret:
Ignition on, enter your normal code and get the green light.
Press "S" and get a bleep
Enter your chosen service code
Press "S" Get a bleep and then six flashes of the greeen light and six bleeps.
Use it like your own code.
This code will remain in effect until you enter your own code again, whereupon it will clear.
Hope that helps
To change the code:
Ignition on
Enter your new code
Hope that helps
Jim
CitroXim
Steve,
I've sent you an email regarding your FCF login problems...
Jim
talbotsteve
