I think you must have been coming back from the same guy as I was going to when we passed on the A38! I got a sunroof wind deflector!citsncycles wrote: Went to collect the back door I won on Ebay today, and ended up with a pair of rear doors plus a drivers front door in cream. One back door has a dent in it and is missing the quarter window and some trim, but the other 2 are pretty good, and will at least give up their rubbing strips even if I don't use the doors. I also have some Mk2 R / TG spec door cards in brown that are surplus if anyone wants them. I'll hold off deciding exactly what to do with these doors until I get the other doors that are coming my way!
The guy had some other bits that I didn't need (alternator, Mk2 dials, Mk2 upper column, Mk2 hatch rear bumper in cream) plus some discs which he said didn't fit his car. He also has a turbo diesel hatchback in a mixture of white and cream which has killed its head that he can't decide whether to fix. I've asked him to get in touch if he decides to get rid so that I can post the details here.
Timex and friends
hilarystone
Re: Timex
Hilary Stone
http://www.Hilarystone.com
Re: Timex
Ah yes - I forgot to post a 'Hilary Stone Spotted'! He did comment he'd sold one, and was quite surprised how popular they are!I think you must have been coming back from the same guy as I was going to when we passed on the A38! I got a sunroof wind deflector!
I didn't think the Xantia looked too bad, particularly compared to my.... Oh, er,oh, I know who you mean, he has a xantia now.. which is also, erm, a bit tired... Raphael, nice enough chap, but a bit odd with his running car on butter type stuff experiments!
Re: Timex
I'm beginning to understand Ian's love/hate relationship with this car!
I filled up at Leominster on the way home from the Tech meet, and have since done just over 300 miles on around 2/3rds of a tank - I'd have had to fill up the GS by now, and would be well on the way through the 2nd tank by the time this needs filling up again!
I'm sure it's getting quicker - I've had an (indicated) 25 in 1st, 40 in 2nd, 60 in 3rd, 70 in 4th and 85 in 5th (all mph
), and I'm spending less time with my right foot buried in the carpet! It's still not right, but it's improving with use.
The list of jobs is growing though - now have a water leak somewhere behind the engine, not going anywhere far until this is sorted! It lit up the light of doom today, but I think I caught it before damaging the engine
In the aforementioned episode, nothing from the cooling fan - it has been working so I need to double check this now.
Also, the lock barrel is on the way out - when I took the key out, it needed lots of swearing and jiggling (of the key, not me) to get it back in, so it now has permanent residence - just as well it's no longer a 1 key car
- Reluctant BXpert
Re: Timex
It's nailbiting stuff. Lots of fab restoration projects going on at the moment
(Raphael ... I think I might have met him when I was working for a Citroen independent in Bristol over 20 years ago. He was quite bonkers then too if it's the chap I'm thinking of - probably in his late 50s now, if not a bit older?)
Re: Timex
I didn't think he was much different in age to me, but what do I know - this is a bloke who starts 95% of his descriptions of people with the word 'short'!
Re: Timex
Raphael isn't very tall, his mother lives over in France, has a part share in some vineyard or something... He had his red BX over there, but somene took it away and scrapped it, he wasn't happy...
He got the Xantia off the bay, and it's cost him a bit since...
Not sure how old he is actually, but I'd guess at mid 40's at least..
Which indy did you work for Sandre?
Re: Timex
Well Timex went to see the Westons today - I managed to get a good look underneath, but forgot the camera
The spheres were a little flat - 40% charge in the front, and next to nothing at the back
One of the rears was US, but the rest took a charge OK - mmmmm, floaty
, although the GS is still a smoother ride!
As well as the welding jobs found already, there are 2 small repairs needed in the front floors - nothing major though
. Overall, much more solid underneath than it looks on top
Found the water leak! the heater hose above the lower engine mount has split at the engine end, plus the short joining rubber between the same area and a length of steel pipe running across the engine doesn't look long for this world either. It's got so bad that the water almost runs out as quickly as I can fill it
I've ordered the short piece from Citroen, but the heater hose is NFP, so the hunt is on for an alternative. Given the poor access, I'm planning on sorting this while the rack's out next week. speaking of which the control valve on the rack is leaking, so it's just as well I have a replacement. when looking at this, Andy said that looking at the state of the rack, it might be behind some of the hydraulic issues.
Also found the major source of the clonk on the front - one of the PAS ram bushes is completely, utterly, totally, absolutely, 100% shot! Also ordered from Citroen. One of the wishbone pivots was loose, so Andy tightened it for me.
Also discovered there doesn't seem to be a coolant level switch, so that's another job for the list.
themildbunch
Re: Timex
Did you get the sphere's recharged? I'd forgotten about this service - how much per sphere / car? I seem to have a collection of old suspension / acc spheres, will they test recharge loose ones too?citsncycles wrote:I visited the Westons today to book the car in to have the spheres recharged, discuss some issues and see if they had any BX's they were breaking. Andy suggested that a pin in the pressure regulator may have got bent, leading to it sticking.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Re: Timex
It may vary from car to car, but mine cost £50 with 3 recharges plus 1 replacement (the accumulator tested fine
) - not checked whether the replacement was new or recharged 2nd hand though, I just know it rides as it should
Re: Timex
Managed a couple more jobs today - tried removing an interior handle from one of the doors I bought last week, but had forgotten about those bloody torx bolts - couldn't find my set anywhere
I then removed the drivers door card to investigate the lock - the operating rod had come off so I've reassembled in the hopes it will stay there this time
My mate John has kindly let me use a space on his drive to work on it this week, but as they're digging up his road tomorrow I tool it round tonight, after topping up the coolant again! I think the water leak is getting worse:
Re: Timex
Let me know the part no. of the hose you require - I have a couple of heater hoses the dealer (incorrectly) supplied for a TD, so they may well fit yours, or at least be made to fit!
Re: Timex
Thanks Mat, but I'll be seeing if I can get some silicone hoses tomorrow, as the one pipe Citroen could supply seems different to the car
Today involved lots of swearing an getting very, very oily! I changed a strut return pipe as the old one was slightly cracked:
the new one actually went on better than I expected, as last time seemed to take ages!
There then followed an afternoon of fighting the steering rack, not helped by a less than helpful Haynes manual. The feed pipes in particular were stubborn, one of which seems to have unions that need an 8.5mm spanner
, and ended up getting cut
. It came out in the end though:
With the rack out of the way, I then removed the damaged hoses. The one that had actually failed came out relatively easily, but the joining pipe that wasn't leaking but looked about to fail was more tricky - in the end I removed the alloy casting on the back of the engine that both these hoses plus the radiator hose all attach to. It was when I was cleaning off some corrosion to the outlets (hopefully not bad enough to scrap the part
) that I made an interesting discovery:
That's a date mark cast into the housing, and it's 1985! It seems that Timex may have it's original engine after all, but fitted with a later head
. I may have a lead on an early head, so watch this space!
So tomorrow starts with a shopping list, some of which is for these parts:
The blanking cup I'm replacing as a precaution due to the state of the other hoses - god knows how the joining piece wasn't leaking as it's in shockingly bad condition. Unfortunately the part I bought to replace it is both too long and too big a diameter, although I'm not sure if the latter is down to a design change or reduced diameter of the outlet on the casting as a result ofmy cleaning off the corrosion:
I also have to get a new return collar for the PAS ram, the old one split as soon as I tried removing the return pipe, and collect the wheels I sourced from Cam Tyres, who are fitting some (hopefully not too expensive) tyres to them.
Re: Timex
Nice work. Don't forget you've got a much nicer steering wheel to go on. I never actually opened the box it arrived in so I hope it's ok... (one of those perpetual 'I'll do that tomorrow' jobs!)
