Jeths lowering project
Jeth
Post by Jeth »
Heres my current BX project
Originally it was 1.4l carb with 4 speed gearbox and no fancy electronics anywhere :)
Spec list:
16V D6C engine
2,5" exhaust
One layer of Dynamat from roof to floor
16V interior
Front lowered about 10cm from original now with 2cm ground clearance in lowest position :)
Fondmetal 4000 rims in 15x7 size
Re: Jeths lowering project
Not really my cup of tea at all but looks very nicely done. There are some right lash-ups about but that certainly has something about it. How does it ride?
Jeth
Post by Jeth »
Dollywobbler wrote:Not really my cup of tea at all but looks very nicely done. There are some right lash-ups about but that certainly has something about it. How does it ride?
Well i've mde front end quite stiff so it wont rub all the time, still alot better than people with "normal" suspension :P
I suppose a BX always has that advantage! Great that people are choosing to modify cars that aren't just Volkswagens. There's far too much of that over here! (by modify, I mean cover in nitromors to remove the paint, angle grind a few suspension coils off and fit a roof rack. That's what I mean by lash-up!)
Not sure about the alloys, but love the rest - I don't usually like white cars!
4 Speed box? never knew they fitted one to the BX!
Is that the suitcase engined version that only had 4sp?
Jeth
Post by Jeth »
There's original engine.
And heres how car looked before i started doing it
Pic of the parts car:
and the reason why i didnt repair that one
mike22861
Post by mike22861 »
Suitcase RE has 5 gears
1992 BX 4x4 Gti aircon Silver
some other newer Nissans
The very base BX in the UK (no trim level, simply BX) had a 4 speed 'box and 62bhp rather than 72bhp. Other countries may have had different models.
Do you think that clear side repeaters would suit it better?
Jeth
Post by Jeth »
mat_fenwick wrote:Do you think that clear side repeaters would suit it better?
In my opinion it would look too white with clear side repeaters, which is why im gonna change front repeaters to orange
Mike P
Post by Mike P »
On the picture above, did you manage to remove the bodykit from the rear arch without damaging it or did you have to sacrifice the bodykit by destroying it to save the inner metal wing underneath?
Mike P
Jeth wrote:In my opinion it would look too white with clear side repeater
Good point. Maybe smoked ones? Anyway, it's your car, so whatever looks best to you.
Jeth
Post by Jeth »
Mike P wrote:On the picture above, did you manage to remove the bodykit from the rear arch without damaging it or did you have to sacrifice the bodykit by destroying it to save the inner metal wing underneath?
Mike P
Heat blower works really well, so yes, without damaging anything.
Mike P
Post by Mike P »
I guess on the back of the metal arch, so that the heat goes into the mastik and does not damage the bodykit?
I've managed to remove the bodykit sections from the sills before but never a rear arch.
Mike P
Jeth
Post by Jeth »
Mike P wrote:I guess on the back of the metal arch, so that the heat goes into the mastik and does not damage the bodykit?
Yeah, heat it until it starts to smoke, then carefully try to strip it off.
