For Sale 1991 Citroen BX 1.6 TGS METEOR
:( It is with a heavy heart that I have decided to sell the meteor.
We are not able to move the boys school and I simply think it is unfair to the car to keep doing over 250 miles a week in it.
I have done nearly 11,000 miles in it since I boought it in January and the only time it failed to get me where I wanted to go was when the ignition module died.
So here's the details and I make no apology for this advert being long.
1991 ( reg 14/11/91) Citroen BX 1.6 TGS Meteorcrystal grey metallic
119,650 miles but this will increase.
MOT until 01/12/12
TAX until 31/12/12
three owners from new including myself ( although wifes name is on the V5 )
Cambelt changed at 107,779 so less than 12,000 miles ago (head rebuilt + tensioners ,fanbelt, hydraulic pump belt ,thermostat and waterpump changed at the same time )
the first owner ( and old gent) had it from new until August 2010 when he sold it to the garage who used it as a runabout until I bought it in January 2012.
Work done since my purchase
front N/S strut return pipe
heater tap/valve replaced with a cleaned second hand one and now works perfectly
two oil and filter changes
new front brake pads ( discs checked and found to be fine )
plugs changed
Dizzy cap and rotor arm replaced
ignition control pack replaced
Alternator brushes changed
recon starter motor fitted
fuel pipes replaced under bonnet (from pump to round thingy, pipe to carb and return pipe reinstated)
and as recently as the CXM meet
lhm tank emptied and cleaned, lhnm replaced and filters cleaned
new upgraded ignition leads fitted
K+N panel filter fitted
the car also benefits from
l.e.d heater panel lights
front splitter
Rear headrests
aftermarket remote central locking ( two fobs)
ring front fog lights ( just need wiring from switch to relay to complete )
sunroof deflector (has a repaired crack )
Will come with the following spares
starter motor
alternator
carburettor
(all need refurbing )
extra spare wheel ( needs new tyre)
rear caliper parts
various manifold gaskets and studs (new)
various water hoses ( some new)
flexi brake hose ( new old stock )
offside front indicator
nearside valeo headlight
nearside green tinted rear light cluster
windscreen washer tank
spare windscreen spray bar
untested chausson heater pcb with all knobs , facia panel and bowden cables
spare dipstick.
I will be removing my stereo system , the rear parcel shelf will be replaced with an uncut one.
The interior is pretty much immaculate
the bodywork is very presentable
there is no rust at all near the door hinges
any surface rust has been rubbed down , treated and primed ready for paint
the dent in the offside wheel cover panel that was present when I bought the car has been knocked out and needs finishing
the rust in the nearside rear wheel cover panel has been ground out , treated and primed
There is a small area of rust in the nearside front inner wheel arch that has been treated and primed ready for paint ( may need a little weld )
The only issues with the car is it can take a little while to start when hot and I think it would benefit from a relay in the starter motor circuit as suggested in the tech section ( I have the relay )
there is an lhm drip from the front near the accumulator sphere ( pipes may just need nipping up ) and the front offside brake bleed nipple is seized ( all others loosened and bled at cxm )
I am looking for as close to £400.00 as possible for the car
If someone agrees to pay the full price, I will also include
brand new clutch cable
brand new front brake pads
brand new rear brake pads
a pair of brand new handbrake cables
pics to follow
Last edited by Mickey taker on Sun Oct 07, 2012 10:31 pm, edited 2 times in total.
Re: For Sale 1991 Citroën BX 1.6 TGS METEOR
no rear arm bearing issues here
this is the panel my mate straightened out , just needs finishing
it used to look like this
there was a little bit of surface rust here
the inner front wing
and sexy 1.6 carbified lump
nearside wheel arch now
and when I got the car
merlyn
Post by merlyn »
Sorry to hear that you have to part with her Mick. Much as I love my car I still have a soft spot for a Meteor, even if yours is the wrong shade of grey. Hope you find a new home for her soon.
Jane
(now sadly gone)
Sorry you're having to sell the Meteor Mickey - but practicalities is practicalities. Hope it finds a good home - it deserves it.
Junkman
Post by Junkman »
This might be a stupid question, but what the heck is wrong with driving a car?
250/week, 1000/month, 12000/year, plus the odd pleasure trip, makes 15000/year.
Isn't that pretty much what the automobile was invented for? It was at least where I'm from.
1992 BX 19 TXD Break
Anyone driving slower than me, is an idiot.
Anyone driving faster than me, is a lunatic.
Its not the cheapest car in the world to do this many miles in on a regular basis ,
I am looking at 1.4 peugeot 306's which will give over 40 to the gallon if driven sensibly and are much cheaper on insurance and tax.
the low mileage of the car was part of what attracted me to it in the first place
less than 108,000 in 20 years is 5400 a year, I have already done double that in the 10 months I have owned the car which is a great testament to the car
the car was always garaged ( which is probably why the body is so good ) and I dont have a garage.
I am just worried the less than cosseted life the car is leading now will drag it down over time and end up with another limited edition BX ending up being scrapped.
I would rather someone who can give it the time it deserves and an easier life will preserve it longer
Tricky call but good luck with the sale. I might be interested in the cut rear parcel shelf if you're in a mood to sell. Don't want to chop up the one fitted at the moment if I can avoid it.
adamparis54321
Post by adamparis54321 »
hi
My name is adam i have owned 3 x bxs and love them
I want to buy your car but do not get paid until 31st october
would you accept a holding deposit of £50 and £350 at the end of the month ?
please advise
i live in essex
adam
Last edited by adamparis54321 on Thu Oct 11, 2012 6:50 pm, edited 1 time in total.
2005 - 1990 Citroen BX14 St Tropez
2007 - 1992 Citroen BX17 TXD
2012 - 1991 Citroen BX16 Meteor
Hi Adam, I have no problem with that, Once the deposit is sorted out I will remove my subs etc so the car is ready for you to collect I'm guessing you would want to collect the weekend 2nd / 4th November ?
Adam, edit your number off of your post and p m. It to me, otherwise you may get loads of dodgy phonecalls
From wierdo forum stalkers
adamparis54321
Hi
I will send money via PayPal tomorrow
Cannot wait - I only will use it 3000 miles a year due to company bike but will make sure it looks as good as this in 5 years !!!
Once I have sent money I will pm you my contact details but please do not sell as this is sold :))))
Adam
Provisionally sold to Adam
Hoorah, and boo if you know what I mean.
yeah I know Tim
