Plastic nut thingumys
BX Bandit
Backslash Bandit
My Cars: Cars
Re: Plastic nut thingumys
Post by BX Bandit »
Mike E (uk) wrote:I have some of these spare, but they never seem to work as intended anyway.
I was going to invent something better, but there is always something more important or interesting to do on the car.
There 3 easy or readily available solutions.
1. Some Xantia ones are similar but have a metal hog ring closing the gap on the part that threads onto the spigot. They are all hidden though - used to keep wiring looms etc in place.
2. Partial success using a cable tie to again close the gap
3. Great success by screwing on an M6 (I think) nut onto the plastic part, again to close the gap.
Pogo
Post by Pogo »
Are these the Xantia ones that I could use?
http://www.ebay.co.uk/itm/CITROEN-XSARA ... 35baa94414" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/ENGINE-COVER- ... 53f0632013" onclick="window.open(this.href);return false;
Might try the nuts first though, I'm thinking perhaps M8?
1990 Black BX GTI
M6 from Bandits post above, just over the plastic nut to close the gap.
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
Pogo wrote:Are these the Xantia ones that I could use?
None of those are what you need pogo. I'm thinking you're right with an M8....
Pogo
Post by Pogo »
Yes, it just seems bigger than M6, thanks for heads up on the ebay ones.
1990 Black BX GTI
barry badger
x 10
Post by barry badger »
The ones I have bought don't fit my car (estate) they aren't deep enough, I think they must be for a hatch, I tried them on my hatchback scrapper and they fit fine.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
michaelr
Post by michaelr »
Here is a way to get those plastic nuts to grip again.
I cut some 12mm x 1.6mm aluminium tube into half a dozen 5mm long pieces, slipped onto the business end of the nuts then crimped slightly perpendicular to the split in the plastic. They grip very well and can be tightened properly.
No more rattly boot liner!
Only problem is the hardware store only sells 2.0 meter lengths and I only needed 30mm ! Maybe I will fix another 65 cars?
Michael, Sydney, Australia
BX19TRI Automatic
DS23 Pallas
Ah, it's finally clicked what people were suggesting with the nuts after seeing Michael's pictures. Guess what I'll be doing tonight!
Aha, it now makes sense with those piccies, thank you :)
Pogo
Post by Pogo »
Did mine today, the 12mm tube didn't work quite as well, so ended up using a bit of chemical metal inside the thread which seemed to work well in the end.
I think it wants slightly smaller tubing than I had.
They certainly grip OK now
1990 Black BX GTI
Did you crimp them? like michaelr did?
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
I just discovered today that i had used metal (steel in my case) tubing also and I crimped (or rather more crudely) squashed mine with mole grips to close the gap a tad. I only have 4 though so I have a few more to do (some for the valver)
Pogo
Post by Pogo »
MULLEY wrote:Did you crimp them? like michaelr did?
Yes, squashed them, perhaps more care was needed?, worked ok though with a dap of epoxy stuff in the end.
1990 Black BX GTI
